Results 1 to 5 of 5
    Senior Member ana_11's Avatar
    EU
    Default Opel z19dt need edc16 file to flash
    I need complet file to program edc16, ext flash and mpc flash.
    Engine code is Z19dt 120 hp ,o dpf filter
    szym10@tlen.pl
    I Salute
    Best Regards
    Simon
    Dec 2010
    Riga
    Quote Originally Posted by ana_11 View Post
    szym10@tlen.pl
    I Salute
    CMD original Full backup
    Z19DT_0281014025
    Estonia
    hei guys,
    could someone explain me how can you use another cars ecu data in your ecu? Do you change the vin code and immo code in some particule maps? Could you reveal where this data (that needs to be changed) is stored ??
    Moon
    what car and what ecu are you talking about. You just want to update your ECU or swap the ecu physically?
    Estonia
    lets take Opel Vectra 2006 Z19DTL 74kW (EDC16C9) and Z19DT 88kW. Both engines are 100% same. Only difference is in ecu software. I can read full ecu soft with BDM from 74kw ecu. And here we have a 88kW ecu soft. What should I change in the 88kW software to get it working in the 74kw car?
    cheers
