Read flash MC9S12XEP768 + 24C128 and write to doner bsi.
MCU is unsecure, xprog, vvdi prog can do
Hi , I have ECU Locked after BSI adaptation with PP2000 (virgin eeprom 24c128 + pp2000 --> engine immobilizer code, keys and VIN).
The car is:
Peugeot 207, 1.4 motor (8FS), year 2008
VIN: VF3WC8FSC34604008
BSI: eeprom 24C128, MCU MC9S12XEP768, PIN code: B3GS
The adaptation process passed, but the engine don’t crank and with the original BSI the engine crank.
I think that the problem is the virgin file !
I need solution to virginzing the donor BSI eeprom!
P.S.
BSI Cloning with copy only the eeprom - not working! Tested!
dvdpgn (28th November, 2021), kvalentino (5th May, 2019)
antwnhszr (6th May, 2019), dvdpgn (28th November, 2021), kvalentino (6th May, 2019), Le-Mans (10th May, 2019)
Solved with XPROG & lion0304 pinout diagram - clone eeprom + MCU
hello please can i have the pinout diagram for this BSI too, thanks in advance
need help
now my goal is to buy xp-005
who will help?
alexbeshko (8th October, 2023), lion0304 (28th November, 2021)
adrian1993 (18th August, 2022), dvdpgn (29th November, 2021), elmaro (15th September, 2022), rafal (29th November, 2021), robert1966 (5th August, 2022), zicimici (30th November, 2021)
@Rafal
Maybe this one from smok helps you?
Cable pinout maybe uhds jtag cable colour?because i dont have this programmer
If i Helped you,use thanks and rep button to thank me back
