Results 1 to 15 of 20
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default Land Rover Discovery 3 Dash problem
    Hello mates,
    I have swap a discovery doesnīt recognise chassis information, can someone please write me right inofrmation on eeprom?
    I am attaching ORI and DONOR just in case ori is corrupted. They are both same reference dash.
    VIN SALLAA187A423988
    280000KM
    Thanks in advance
  2. The Following User Says Thank You to McDowell For This Useful Post:
    alclot (7th May, 2019)
  3. #2
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Default Here is your file.
    original mileage is 287.356 kms and here is your original file fixed.
    Good Luck!
  4. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    alclot (7th May, 2019), McDowell (7th May, 2019)
  5. #3
    McDowell's Avatar
    Feb 2019
    Zamunda
    Quote Originally Posted by jomberykaso View Post
    Good Luck!
    Many thanks I will try and report
  6. #4
    McDowell's Avatar
    Feb 2019
    Zamunda
    Quote Originally Posted by McDowell View Post
    iIt did not work, still saying he VIN number does not match, any ideas?
    Thanks a lot
    Sep 2013
    I put the vin number in the correct place . You can compare them and verify if I put the correct one
  8. #6
    McDowell's Avatar
    Feb 2019
    Zamunda
    I know, itīs strange. I have written your eeprom modification to both ori and donor.
    The original one which is flickering on and off says the VIN is correct, while the other one still having an old number, I know about 35080 delete and write, maybe I have had a mistake. Iīm gonna read donor 35080 anc ompare with yours and see if it still the same.
    Thanks a lot
  9. #7
    McDowell's Avatar
    Feb 2019
    Zamunda
    Is it possible the IMMO data is not in 35080? because miles change but not the VIN number...
  10. #8
    Moderator
    PremierD's Avatar
    Jun 2009
    Immo data is in the Micro mate .. you need to swap both ...
  11. The Following User Says Thank You to PremierD For This Useful Post:
    McDowell (14th May, 2019)
  12. #9
    McDowell's Avatar
    Feb 2019
    Zamunda
    Quote Originally Posted by PremierD View Post
    Ok but there is an issue, micro is broken....its flickering on and off the dash and if I warm it up works fine.
    Any pinout to read it in the board?
  13. #10
    Moderator
    PremierD's Avatar
    Jun 2009
    No immo data no go mate ... so you are screwed.. sorry
  14. The Following User Says Thank You to PremierD For This Useful Post:
  15. #11
    McDowell's Avatar
    Feb 2019
    Zamunda
    Bbut is there any chance to read it and write? because is working when warm, so i could read it warm and it will be fine.
  16. #12
    levisdj's Avatar
    EcuLand
    Then keep it hot while reading ....
  17. #13
    McDowell's Avatar
    Feb 2019
    Zamunda
    Quote Originally Posted by levisdj View Post
    Do you know how to read it? sorry for so many questions :s
  18. #14
    it depends on what kind of MCU is there.
    You did not write anything about it nor post picture of it.
    WBR, Marek
  19. The Following User Says Thank You to tech_cz For This Useful Post:
  20. #15
    McDowell's Avatar
    Feb 2019
    Zamunda
    Quote Originally Posted by tech_cz View Post
    WBR, Marek
    Thanks for your reply. See attached itīs 64f2638f20
    Cheers
