Results 1 to 14 of 14
    lion0304's Avatar
    Oct 2014
    Default Mini CAS3+ need check dumps
    I have a CAS3+ mini 61.35 - 9221719-01 that i need check Flash if it is correct and good with this CAS number.
    Thanks in advance.
    droidwayne65's Avatar
    Aug 2015
    North America
    Don't have another flash with which to compare but it's part number matches the label. On the other hand, eeprom is screwed.
    <---- Coin of the Realm.
  3. The Following User Says Thank You to droidwayne65 For This Useful Post:
    lion0304 (7th May, 2019)
    lion0304's Avatar
    Oct 2014
    Yes i see eeprom in boot mode and have already repaired.
    I'll write ONLY eeprom and try. Thank you for your advise.
    p1et's Avatar
    Oct 2013
    What's the reason of CAS being in boot mode? Did you try to downgrade CAS or what?
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by p1et View Post
    I have no idea, a friend garage bring me this Cas3 and said CAS doesn't work.
    He also give another CAS order dealer but with another part number, diffrent MCU 0M23S. In this CAS 2 keys: 1: 7936 and other 7946.
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Here is a complete Set with your CAS3 + and ECU Full Dump
  8. The Following 3 Users Say Thank You to koolstuff For This Useful Post:
    dekimin (1st May, 2022), lion0304 (8th May, 2019), Stelaras26 (8th July, 2021)
  9. #7
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Make Key with tango using eprom of ecu dump and start car, but you'll have to sync EGS ans ELV, CGDI or FVDI or Maxisyscan do it
  10. #8
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by koolstuff View Post
    Thank you mate, i'll need only good flash, because car still has working key.
  11. #9
    lion0304's Avatar
    Oct 2014
    With your good Flash dump, i just compare with mine and flash is the same.
    So i just write eeprom repaired and hope everything will go fine.
  12. #10
    lion0304's Avatar
    Oct 2014
    Update my case: Write good eeprom and flash, mount on car. No igntion, no ELV....only wiper work.
    I use the doner CAS with 0M23S, make new key and car start now. So original CAS hardware is completely dead.
  13. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    electronicar (27th July, 2022), p1et (9th May, 2019)
  14. #11
    Jun 2014
    Default plz help
    hello need pass thanks
  15. #12
    Apr 2013
    cyprus
    hi, can i get pass pls. thanks
  16. #13
    Aug 2013
    TURKİYE
    password please!!!!!
  17. #14
    Aug 2013
    TURKİYE
    password please!!!!!!!!!!!
