Results 1 to 5 of 5
    rob h's Avatar
    May 2011
    Default Transit SID211 ids programming
    Hello guys,
    2017 Ford Transit
    Old Sid211 ECU complete destroyed.
    Replacement sid211,
    Same partnumber, GK21-12A650-CA
    Soon as i enter pcm partnumber in ids, vcm2
    The configuration was incorrect message appears.
    Same with the tear tag GK31, also not accepted.
    I tried a different sid211 partnumber GK21-12A650-CAA (with extra A)
    This whas accepted.
    Why does my pcm not accept Both part org and tear tag number?
    Any help would be apreciated,
    Greetings Rob
    rob h's Avatar
    May 2011
    Entering GK21-12A650-CA still not accepted.
    However GK21-12A650-CAA is
    GK21-12A650-CAB also accepted
    A third letter at the end, shows me a automatic gear type equipted vehicle.
    I work with a passthru device, update with latest ids software, with good internet connection.
    Selecting the car, based on bcm works, till i get to the programming of the pcm.
    Programming failed, after hooking up the replacement pcm.
    Why it fails, dont know, how can i find out, why it wont program?
    Are there tips or tricks, logs, something to guide me.
    Any help would realy be apreciated
    Dec 2018
    12A650 is PCM hardware # . best to use SW calibration ID# , so the one with "14C204" in it should work IDS has been fussy for years on this process. Take the SW ' calibration ID # from the passenger B post.
  4. The Following User Says Thank You to green1 For This Useful Post:
    rob h (25th May, 2019)
    rob h's Avatar
    May 2011
    Thank you,
    GK31-14C625-CDP This is the tear tag in the door post.
    Entering the GK31,in the tear tag section, also found to be incorrect.
    GK31-14C625-CDP is the tear tag.
    And pcm number GK21-12A650-CA
    When i type the first and last digits of the tear tag, in the pcm section,
    GK31-12A650-CDP it is accepted.
  6. #5
    May 2018
    Sorry to dig up an old thread, did you ever get this sorted, have same problem with same ecu and part number, thanks.
