Here you are.
hy, i have a skoda octavia 2010 1.9 tdi edc 16 , dash 1Z0 920 903 D
Address 17: Instruments
Control Module Part Number: 1Z0 920 903 D
Component and/or Version: KOMBI H21 0110
Software Coding: 110F00
Work Shop Code: WSC 73430
VCID: 3663C05389B2A6A8CA7
i need to help me to convert miles to km , i have a vag com and change the country Germany and show miles
atashed the memory read with fvdi
Here you are.
cristion (15th May, 2019)
don t work , show miles , thanks
someone else to help me with the conversion or other software ware
It does work, maybe you need to check the menu, there you must also choose KM instead of mileage.
Maybe also check coding.
Ahhh this is a low-line cluster?
Then it won't work, sorry.
don t have a menu change miles to km, thanks
hy , need dump for skoda octavia dash 1z0 920 812d with 226 000 km ,i read and write with carprog but when i put dash on car apeears 250.000 ,
please help because i check with lincnik 48 tel me i have 226... i dont now were i mistake .
thank all
This is the low-line cluster. There is no km sign in the display, only miles.
The value of odometer will change from miles to kilometers, but after the numbers you will still have miles.
You need to change display to see km.
solved to replace dash and add key , thanks
send the config data
solved direct obd with carprog online suport
thx all .
