Results 1 to 3 of 3
    Jul 2016
    Ukraine
    Default SANTA FE 2007 EDC16C39 help DPF OFF
    Help remove the DPF in Santa Fe 2.2 2007 edc16с39, with the disconnection of sensors and errors P0545, P2032, P2002. Automatic transmission. Thanks.
    credoline's Avatar
    Србија
    Here is it. It is with or without sensors i do not know. But solution work.
  3. The Following User Says Thank You to credoline For This Useful Post:
    urametz (12th May, 2019)
    Jul 2016
    Ukraine
    Quote Originally Posted by credoline View Post
    Thanks again . This solution is from one well-known program and it really works with connected sensors. My first exhaust temperature sensor before the turbine is faulty broken. Therefore, the error p0545 remains, although it does not enter the car in the limp mode and the check does not light up. But I would like to make a clean. Delete this error or all associated with the sensors. It is not possible to fix the temperature of the sensors as in the case of 2.0 edc16c39 Hyundai tuggson. Therefore, a request to those who can remove p0545 at least or on all sensors.
