Results 1 to 1 of 1
    Mar 2019
    Default VAG SIemens PPD 1.5 03G906018CE SN100L1000000
    Hey guys,
    Can someone look at my map and tell me if there is any blatent issues.
    The car has been remapped twice by two different companies but both times only achieving 155hp and 390nm of torque on the dyno. No matter what values are changed in the map there is literally no difference. Im pretty sure my cars hardware is all fine so am leaning towards a limiter not being removed. Turbo is genuine and only a year old and has no play in the shafts, MAP sensor has been replaced, all boost pipes checked and sealed. Vacuum lines checked, MAF cleaned. New air filter and fuel filter, just have the N75 left to replace and then im out of ideas. EGR is deleted and mapped out (car has no DPF) exhaust and CAT are stock. Swirl flaps have been removed but not yet mapped out. Car drives faultlessly with no smoke, MPG is great too and the car does not feel slow either due to the good torque but after 3500rpm boost HP torque and fuel just drops off rapidly.
    Any help would be greatly appreciated.
