Results 1 to 2 of 2
    Nov 2015
    Default Marelli MJD 9DF gear ratios map?
    Hi, I'm looking for the gear ratios map in this ecu, the car has been fitted with a different gearbox with longer ratios and have problems with the gear indicator and cruise control. Maybe someone with a damos for this ecu could help finding those maps? Thanks in advance
    Dec 2018
    Quote Originally Posted by m2312l View Post
    Hi, I've a problem with cruise control on Fiat Punto 1.3 mjt!
    Did you solve the problem? I'm also looking for the map portion of the cruise control.
    Thankss
