Hi, I clear crash data from the airbag module now I get the code B1322 I think that need a WCS reset or calibrate Can you recommend me a scanner can do that its perfect if it is a cheap scanner Im a new in this. Thank you. And If some one need the cleared file for 95910 2K051 send a pm and I will send you
reprogramme the airbag module now I get this code feet need to reset WCS Scanner recommend me for thisreprogramme the airbag module now I get this code feet need to reset WCS Scanner recommend me for thisreprogramme the airbag module now I get this code feet need to reset WCS Scanner recommend me for this
