Maybe there is problem with checksum. I corrected it and it may work. you can try
fabiastg1egroff cs ok.rar
I have a "little" problem.
PCR 2.1 unlocked with KESS V2 (clone)
KESS ID says: Installation: R4 1.6l TDI UNLOCKED
VCDS says: SAMPLE
But I cannot write mod file (stg1+egr off), always error after write and car wont start.
After that writing ORI file allways success and car starts.
Both files attachment.
Can somebody help me?
If i helped, press THANKS and Reputation
Still same problem. "..error occurred during the writing..", and ORI -file still works.
Maybe kess do wrong checksum. If cks is made by program, you can try use writing without cks correction. Search in this forume this file.
If i helped, don't forget push thanks + rep
Still same problem
is not chks problem
problem is in your mod file
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Quilem (19th May, 2019)
why you touch n75 map turbo not need so much dw also ect and these is automatic gearbox
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
