Results 1 to 15 of 15
    Apr 2019
    London, UK
    Default Is it possible to map off a MAF sensor on 2.0tsi cczb med17.5?
    Hi all,
    My car doesnt like MAF sensors. Every time i plug it in the car hesitates. Ive tried a new MAF too.
    Is it possible to take the MAF off and if anyone can do this i will be greatful
    Thank you
    Seat Leon 1p FR 2009 2.0 TSI MED17.5 CCZB
    My mods
    Ram air induction
    Intercooler
    Hybrid Turbo
    3inch turbo back exhaust
    R8 coils
    jameshal18's Avatar
    Feb 2018
    EU
    If you unplug MAF, does it work fine or not?
    If i helped, press THANKS and Reputation
    Apr 2019
    London, UK
    Hi there, Yes with it unplugged it runs ok.
    jameshal18's Avatar
    Feb 2018
    EU
    send fault code
    Apr 2019
    London, UK
    P0100
    does drink alittle more but other than that it's fine
    jameshal18's Avatar
    Feb 2018
    EU
    Quote Originally Posted by alextinou View Post
    P0100
    Hello friend. here is the file. You can try and report. No checksum corrected but kess v2 corrects it if i am sure.
    Pass by pm
    eeti(SEAT LEON 2.0_TFSI_200 VERSION_#03 SW#1037501823)P0100.rar
  7. The Following User Says Thank You to jameshal18 For This Useful Post:
    alextinou (18th May, 2019)
    Jul 2013
    yorkshire
    May be you have un metered air, manifold leak and the air mass cannot keep up. I have come across this before.
  9. The Following User Says Thank You to autoden For This Useful Post:
  10. #8
    jameshal18's Avatar
    Feb 2018
    EU
    he has also bigger turbo so maybe needs bigger maf
  11. The Following User Says Thank You to jameshal18 For This Useful Post:
  12. #9
    Apr 2019
    London, UK
    Im not sure but i do have another error now which is MAP/MAF Throttle position P0068 Correlation, thank you all for helping me
  13. #10
    Apr 2019
    London, UK
    When blanking MAF are you not supposed to set the MAF reading to one level in the ecu ? Im not sure how it works im leaving it to you professionals haha
  14. #11
    Apr 2019
    London, UK
    You maybe right about a leak. My cars turbo will kick in around 2.5k however it will full boost 4.5k which i dont think is normal. I cant seem to track down the leak. Even with a smoke tester nothing shows. Maybe because maf is no good ?>
  15. #12
    jameshal18's Avatar
    Feb 2018
    EU
  16. The Following User Says Thank You to jameshal18 For This Useful Post:
    alextinou (19th May, 2019)
  17. #13
    Apr 2019
    London, UK
    Default Original file
    For James original file
  18. #14
    Apr 2019
    London, UK
    Default JAMES
    James this already has MAF off. Can you simply delete P0068 only.
    Thank you
  19. #15
    jameshal18's Avatar
    Feb 2018
    EU
    Thank you
    Here friend. pass the same.
    eeti(SEAT LEON 2.0_TFSI_200 VERSION_#03 SW#1037501823)_MOREPOWER_P0100_P0068.rar
  20. The Following User Says Thank You to jameshal18 For This Useful Post:
    alextinou (24th May, 2019)
