Toyota Rav4 from 2008 with key less system
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Timisoara
    473
    Downloads
    166
    Uploads
    Default Toyota Rav4 from 2008 with key less system
    I have a rav4 with 2 keys and the system is keyles go and entry
    remote lock/unlock, keyless entry and go not working on both keys
    keys tested with key tester and are 434 MHz and remote led is lighted on one key battery is new in both keys
    engine start is working with both keys if key is near start button
    i try to add key but with no joy
    ori key 1
    Recognized as: Texas Crypto 40/80 bits
    ID 6D - 67/68/70 - JMA TP xx
    Password: 94 - Locked
    Identifier: 47 - Locked
    Serial number: E9A6B91A - Locked
    Secret key: Locked
    Configuration: 0086 - Unlocked
    Mode: 40 bits
    Toyota/Lexus smart key
    ori key 2
    Serial number: E68B5B1A - Locked
    Secret key: Locked
    Mode: 40 bits
    and keys i want to add
    Identifier: 0A - Locked
    Serial number: 47E9371A - Locked
    Secret key: Locked
    Mode: 40 bits
    Identifier: 38 - Locked
    Serial number: 93F1281A - Locked
    Secret key: Locked
    Mode: 40 bits
    i have teachstreem and deleted all keys except one
    but i cannot register keys at the end key register error
    keys that i want to register are OK?
    Thank you
    Edit photo
    The black is key I want to register key is virgine
    Grey is ori key of the car
    I'm afraid to connect OBD pin 4 and 13 for 35 min because if keys are not added.... at least car was a runner when it came to me
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Quote Originally Posted by clauberty View Post
    ori key 1
    Secret key: Locked
    Mode: 40 bits
    ori key 2
    Secret key: Locked
    Mode: 40 bits
    Secret key: Locked
    Mode: 40 bits
    Secret key: Locked
    Mode: 40 bits
    Thank you
    Edit photo
    Wich region your car? Usa? Europa? Japan? Saudia?
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    In foto Smart keys -Tokai rika 433mhz. is europa or saudia or japan region. If yuor car from this region your have problem with smart key remote antena. Chek antena cirkuit or replase antena
    Timisoara
    473
    Downloads
    166
    Uploads
    ok car is for Europe but i try to learn other second key and no joy,
    car have 2 keys i deleted one -> make it virgin and try to re-adapt-it -> no joy
    i buy 2 black keys (second hand) make them virgin and try to adapt -> no joy
    it is not clear for me why i cannot adapt key to car immo
    car start when i put key next to start stop button, when i in the process of key learning ori key detected (2 beeps) but next key is not adapted
    remote not working key-less entry / go not working
    Timisoara
    473
    Downloads
    166
    Uploads
    Quote Originally Posted by artcom View Post
    when you say smart key antenna you are referring to the car antenna or key antenna?
    all the door handles have antenna, i tested them with oscilloscope and there is signal same for start stop button
    where is the rest of antennas?
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    I meen door Control Receiver antena
    Timisoara
    473
    Downloads
    166
    Uploads
    can you tell me where is tat located
    Thank you
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Foto in arhive
  9. The Following 2 Users Say Thank You to artcom For This Useful Post:
    clauberty (20th May, 2019),Nchafuan (14th September, 2019)
  10. #9
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Chek antena & sertification ecu circuit. Replase antena.
  11. #10
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Antena location
  12. #11
    Timisoara
    473
    Downloads
    166
    Uploads
    Antena location
    i put antenna from a car that is ok and the same behavior
    can you tell me where ID CODE and ECU Aggregation is located
    Thank you
  13. #12
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Diagnose smart ecu. Check smart for errors?Check smart for errors?
  14. The Following User Says Thank You to artcom For This Useful Post:
    clauberty (24th May, 2019)
  15. #13
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Id code in the same place where all immobilizers for air conditioning unit.
    smart ecu for the glove compartment next to engine ecu
  16. The Following User Says Thank You to artcom For This Useful Post:
  17. #14
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Foto upload tomorow
  18. #15
    artcom's Avatar
    Nov 2015
    27
    Downloads
    Uploads
    Foto smart &id code
  19. The Following User Says Thank You to artcom For This Useful Post:
