Results 1 to 8 of 8
Thread: Rpm limitation
    Apr 2016
    Default Rpm limitation
    Hello guys,
    I want to ask if its possible to do a limitation (max) of rpm till 2900 a 3000 in stationary (manual gearbox) for a vw touran 2007 diesel 1.9 tdi engine bkc...?
    Nov 2018
    england
    Yes it is quite easy, set torque limit to 0nm at desired revs on your chosen drivers wish map then change drivers wish selector to make it select your map when stationary.
  3. The Following User Says Thank You to dannyanto9292 For This Useful Post:
    Charli (20th May, 2019)
    Apr 2016
    I really don't know how to do it, so you need to flash the ecu for this?
    Apr 2016
    Quote Originally Posted by dannyanto9292 View Post
    I really don't know how to do this, so you need to flash the ecu for this?
    Nov 2018
    england
    Do you own a mpps cable or any other device to read the dump from your ecu? If you send me your original file i can make the changes for you, if you are not comfortable doing them yourself.
  7. The Following User Says Thank You to dannyanto9292 For This Useful Post:
  8. #6
    Apr 2016
    I have add the flash for the ecu, it is done with k tag
    Thanks mate
  9. #7
    Nov 2018
    england
    Greetings, here is your file.
    Rpm's have been limited to 3000rpm when stationary, Please test and report.
    Regards.
  10. The Following User Says Thank You to dannyanto9292 For This Useful Post:
    Charli (7th August, 2019)
  11. #8
    Apr 2016
    Regards.
    Sorry for the late reply, thanks a lot
