Results 1 to 8 of 8
    Feb 2016
    26
    Downloads
    Uploads
    Default Xsara picasso 2001 2.0 hdi edc15 pin from ecu
    Hello.Can anyone find pin in this ecu dumpor do immo off?Ecu is EDC15C2 with 1 plug
    toutougsmserver's Avatar
    Jan 2013
    inside map
    31
    Downloads
    5
    Uploads
    dump not good
    try to read again
    chiptuning custome stage1-stage2-stage3
    DPF-EGR-ADBLUE-DTC REMOVE
    MAGICSPORT X17-----KTAG+KESS-----AUTOTUNER-----WINOLS
    Feb 2016
    26
    Downloads
    Uploads
    Readed ok I think, maybe it is corrupt...
    Feb 2016
    26
    Downloads
    Uploads
    You sure that dump is bad?
    Jun 2010
    EU
    103
    Downloads
    Uploads
    In these cars till 2002 no pin stored in engine ecu.You can get pin from bsi,read nec mcu inside.
  6. The Following User Says Thank You to stoyanov For This Useful Post:
    Romcik (18th May, 2019)
  7. #6
    Feb 2016
    26
    Downloads
    Uploads
    Can do correct immo off someone?Ecu is with 1 plug.
    I do by yourself, will try.
  8. #7
    Feb 2016
    26
    Downloads
    Uploads
    This file is not working.
    Any solutions to start car?
    Also desolder 5P08 eeprom at all, car not start.
  9. #8
    Feb 2016
    26
    Downloads
    Uploads
    Have anyone working solution for immo off for thi ecu?
