Results 1 to 2 of 2
    May 2019
    Default Golf MK6 01042 NEED LONG CODING
    Hi All,
    I have a problem that started after i have changed the ABS Module. On the Autoscan im getting a few errors, the main ones are:
    01042 Control Module not coded
    00778 Steering angle sensor -no or incorrect basic settings
    01423 Transverse acceleration sensor -G200 - no or incorrect basic settings
    I need to find out the long coding for the ABS module. I have tried other long codings from other Threads but they dont help me. Any help would be appreciated
    Autoscan Result:
    VIN: WVWZZZ1KZBW305711 License Plate:
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component and/or Version: ESP MK60EC1 H31 0108
    Software Coding: 00000000000000000000000000000000000000
    Work Shop Code: WSC 01357 011 00200
    4 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Time Indication: 0
    Date: 2027.14.27
    Time: 12:43:39
    Freeze Frame:
    Count: 3
    Count: 12
    Count: 20992
    Count: 195
    Count: 43264
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Mileage: 167127 km
    Time Indication: 0
    Date: 2027.14.27
    Time: 12:43:32
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 4096
    Count: 279
    Count: 43264
    Count: 0
    Count: 65280
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Mileage: 167127 km
    Time Indication: 0
    Date: 2027.14.27
    Time: 12:43:32
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 4096
    Count: 295
    Count: 43264
    Count: 0
    Count: 65280
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Mileage: 167127 km
    Time Indication: 0
    Date: 2027.14.27
    Time: 12:43:32
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 4096
    Count: 270
    Count: 43264
    Count: 0
    Count: 65280
    Count: 0
    Dec 2010
    A litlle bit of data to help you
