Hallo
If someone is interested i'll post some usueful info i've collected.
If you want to add a remote to Fiat Panda 2series (pcf7941) and you don't want to buy a expensive remote from Fiat.
First.Find a working used remote.
With the help of KD-X2 device , using the renew remote function , you can reset the used remote to unlocked state.
After that read the Siemens Bcm confdata with AVDI.
With TMpro2 and Panda Bsi acrivation module active, load the bcm file, program the unlocked used key.
Rewrite the Tmpro' generated file to Bcm.
Et voila'.The used remote is adapted to your car, fully functional.
Hope this help.
all great but, five years ago, you buy an Asian pilot, you put two little stones into it, do not let the weight match and the original
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
Brof (18th June, 2019)
Yeah, good to know but let's be honest, noone will pay proper price for original remote key for this box on wheels called Panda
Hallo
Considering the huge amount of Panda around, probably you can help someone to have his remote functional without wasting to much money.
We have a lot of request about this remotes (pcf7941) but the original remote is priced to high.
You can reuse old remotes but you need TMpro2 module to have this remote properly programmed.
Changing only pcf7941 with virgin one will let to have a usable key for starting but remote will not work.
By the way someone started recently to sell some clones at resonable price.
Cheers
These Pandas are nasty little buggers. There are cheap non-original keys from China which have to be programmed the same way Mr. Armpower explained.
You can read BCM by OBD and you can make dealer key and program to the car but remote will never work unless you use TMPro to prepare the dealer key.
Only TMpro can do it. Shame on you AVDI and VVDI... not even EFFI can do it.
Have you tried ori avdi last update?
Hahah this was a joke, right?
A Itallian seller sold this keys ( think are chinese copy) but i never seen one sold by chinese sellers.
AutoTkey have you an idea which chinese seller can have someone for sale?
Thanks again
No panda were I live pointless investing on remotes...
Meat-Head (18th June, 2019)
