Thread: MJD9F P2458 off
    Nov 2015
    Default MJD9F P2458 off
    I switched off egr and dpf on a Fiat 500L 1.3 multijet with Marelli MJD9F ecu using Swiftec 1.9.7.4.
    For a few months it worked well now dtc P2458 (Diesel Particulate Filter Regeneration Duration) is on and I don't know how to turn it off. I included both stock and modded file.
    Is there a way to remove this dtc? MJD9F.zip
    Sep 2013
    look what you attached.
    May 2018
    Quote Originally Posted by ilDandi View Post
    How read and write this ecu?
    Wysłane z mojego SM-G973F przy użyciu Tapatalka
    May 2018
    Your files is not from MJ9DF......
    Nov 2015
    Quote Originally Posted by dudus8 View Post
    I read with CMD
    Sep 2013
    You have magical equipment that turns Marelli file into Bosch file.
  7. The Following 2 Users Say Thank You to pike For This Useful Post:
    konq100 (19th May, 2019), morgano (19th May, 2019)
