Check if ecu is swimming! Its under the windscreen panel.
Hello I am looking for a bit of help I have a corsa d 2011 with the a10xep engine there is something draining my battery I have ran my opcom on it and the only error I can’t remove is u2100-00 canbus communication error I left the car for 30 min and I was still getting a drain on the earth of 0.31 and power cable 0.34 I have just put in a new battery
Jinkien02 (11th June, 2019)
I tried that my ecu is located in the side of my battery tray thanks for responding
Then put your meter on and start pulling fuses. When the draw drops find out what is on that circuit. Have you got a hands free fitted?
I haven’t got a hand free there was a thin red wire with a inline fuse don’t know if there was a black box fitted previously but there is no fuse connected and the wire is cut I will try pulling the fuses cheers for all your help
I tried pulling the fuses out one by one in the box under the bonnet but it did not Chang the reading
Did you try with fuses inside the car? Then disconnect fuse box or ecu. You have to isolate to move on
Radio used to cause problems like that .. micro staying powered up but no sign on the radio itself .. pull out and disconnect (worth a try )
Jinkien02 (11th June, 2019), racin-snake (25th May, 2019)
I had it in a garage to get it looked at and he said it was the head unit that was causing the issue so removed that and it’s still doing the same I have disconnected the fuse for the stereo and that wasn’t it also the interior light want that I was out in it for about 30 min drive and today it’s flat again at my whits end with this car
Advertising:-
go go buy a thermal imaging camera £150 ish so told
use that , if no good just look at body parts with it
not sure, it has. Battery live (some do) airbag module fully with water
take photo of all fuses, pull the lot out, if drain then something that’s infused, alternator
I don’t know we’re these are racin
On a right hand drive vehicle its behind the glove box https://www.youtube.com/watch?v=A1jnQb8R8DY
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
Had the same on an Astra H it was the alternator draining the battery, worth a check.
I have just ordered a new alternator I will change that and hopefully sorts the problem cheers for all the help
