Contact a local tuner with dyno, if you really love your car.
Of course I will .. but for the time being I thought someone who has a good one might want to share until I start modifying.
First of all - go wideband and 1MB file ECU
Otherwise it's asking for trouble
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
Hey there, do you know what is needed to a wideband conversion?
hello
send pm
Chiptunning all stages
Egr. Fap/DPF. Torque Monitor disable. CVN Bypas
DTC removal. AdBlue . Hot Start Fix. Speed Limiter. Lambda remove.
MAF remove. TVA remove. Flaps/swirl flaps
morgano (18th June, 2019)
How should somebody help without file :O?
