Results 1 to 7 of 7
    Aug 2011
    Default W218 milage correction
    I have W218, year 2015. Can anyone correct km in this 25128 eeprom? Original km is 107942 and I need cca. 57000. If assist service history is stored in dash eeprom, can this also be corrected? I used Codecard Canemu2 emulator in dashboard and on OBD connector. Will this be enough to prevent mercedes star diagnosis from reading actual km?
    I am aware of dpf old mileage, gearbox etc. ... I'm only trying to do a semi-decent job
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by pipina View Post
    Here is your file km changed only.
  3. The Following User Says Thank You to drpeter For This Useful Post:
    pipina (20th May, 2019)
    Aug 2011
    Hi, corection is OK as when puting in the car it show 56992km. But after ignition ON it jumps back. I'm conecting someting wrong or codecard emulator don't work on MB W218 -2015?
    drpeter's Avatar
    The Netherlands
    wrong selection try see photo!
  6. The Following User Says Thank You to drpeter For This Useful Post:
    pipina (22nd May, 2019)
    Dec 2016
    central uk
    original poster may want to remove chassis number from 3rd jpeg (just a thought)
  8. #6
    Oct 2016
    may also want to block out vin # from third picture (top left)
    Thanks and Rep if I've helped you.
  9. #7
    Aug 2011
    Quote Originally Posted by drpeter View Post
    Hi, work OK. I use this sheme as car is after 2014. Can you please explane me as per manual this is for W204 and W221 ... is W218 same platform? What configuration to use on obd conector?
    https://app.box.com/s/0w8o5618z782jia8m4wqyk9d52mchofn
