Results 1 to 14 of 14
Thread: vw rcd 310 code
    Default vw rcd 310 code
    pls i need vw radio code vwz1z3
    5k0 035 190 rcd310
    Croatia
    Hello
    You need to read Processor NEC and eeprom.
  3. The Following User Says Thank You to Mezz_cro For This Useful Post:
    nokwueze (21st May, 2019)
    Quote Originally Posted by Mezz_cro View Post
    Hello
    check the files i have them
    richiebb's Avatar
    Aug 2015
    Argentina
    Code is 0092
  6. The Following User Says Thank You to richiebb For This Useful Post:
    Quote Originally Posted by richiebb View Post
    Code is 0092
    wrong code
  8. #6
    richiebb's Avatar
    Aug 2015
    Argentina
    Quote Originally Posted by nokwueze View Post
    wrong code
    95128 dump its wrong.
    try this dump edited, whit code 1234
  9. The Following 2 Users Say Thank You to richiebb For This Useful Post:
    nokwueze (21st May, 2019), Zann (21st May, 2019)
  10. #7
    pls the code did not work i need code for this radio z1z2 5m0 035 186 j
  11. #8
    smoggy's Avatar
    Apr 2009
    UK North East
    if this EEPROM is to go with NEC from post 1 then they do not match
  12. The Following 2 Users Say Thank You to smoggy For This Useful Post:
  13. #9
    thanks here is the nec file
  14. #10
    richiebb's Avatar
    Aug 2015
    Argentina
    the eeprom 95128 is still wrong, so with the new dump NEC try this file (95128) code 1234
  15. #11
    yes it did not work
  16. #12
    pls help me with new one
  17. #13
    richiebb's Avatar
    Aug 2015
    Argentina
    yes it did not work
    save this new 95128 edited - code 1234.zip in 95128, If the last dump of the NEC belongs to the unit, it should work.
  18. The Following User Says Thank You to richiebb For This Useful Post:
  19. #14
    pls sir i tried this file on two different radio and the radio went dead and i tried put to back the original file back the radio refuced to work pls sir how can you help me out
