Results 1 to 9 of 9
    Jan 2013
    Inside ECU
    Default Need Astra h z19dt 120 hp, EDC16C9 dpf and egr off
    Hi i need dpf and egr off for astra h 1.9 tired all solutions : asc, volta , ecusafe, swiftec, saturation is growing.
    3inferno3's Avatar
    Nov 2014
    Europe
    Few days ago i did vectra c with sane ecu.. in ASC solution is edc16c9 dpf egr off. first try it. in my case was ok. if not we do manual
    Jan 2013
    Inside ECU
    The car is working very well. It has power, no smoke but the saturation is growing. It will enter limp in 500-1000 km. That is the only problem. Solution mention by you is working in my case too but will enter limp in short time. So recall that vectra or you will be called by the owner.
    Jan 2013
    Inside ECU
    Does anyone have a manual solution?
    Jan 2013
    Inside ECU
    Please someone help with dpf and egr off. I have no solution.
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Here is my file, it works ok on a few cars from at least 2 years...
    No checksum.
  7. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    leotdx (23rd May, 2019), pike (23rd May, 2019)
    Jan 2013
    Inside ECU
    Thank you bobolin. Is this manual solution. Do i disconnect sensors?
    bobolin4o's Avatar
    Do what you want... there is not problem if they are disconnected, or not...
  10. The Following User Says Thank You to bobolin4o For This Useful Post:
  11. #9
    Jan 2013
    Inside ECU
    Ok thank you bobolin for your help.
