Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    May 2019
    Default 2001 VW Beetle immo off
    Hi Guys,
    I keep getting Block protected come up on read Any ideas?
    Reading B58085 as a 24C02 as everyone has recommended.
    May 2019
    Well Block Protect:0000H--03FFH to be exact
    brend's Avatar
    Oct 2015
    Same where
    Why is it so complicated!...............
    Desolder/read and if need help load !
    If yours programmer not read this,check pins!
    It's standart eeprom and it's without same protection.
    Quote Originally Posted by Hebbydee View Post
    NB!!! Don't ask in PM old file password , Im not remember.
    May 2019
    Yes do not know why so difficult for a straight forward job. Connections seem all fine and Batronix normally works well. I even tried it on an old Wellon which is where I get the Block protected bit but both read same blank.
    brend's Avatar
    Oct 2015
    Same where
    Pin connection 100% or wrong set type in programmer!
    May 2019
    Any idea of what set type you would use for this going by the other forum threads need to use 24C02 I am all out of ideas checked connections, 20190522_213541.jpg
    May 2017
    Ecunumber? i think you read wrong eeprom + bad soldering job bro
    May 2019
    Tried reading the Fairchild chip too but same blank read. I assume has to be set type I really don't know. I just read C63 eeprom fine using same adapter.
    And that is factory solder job before removed chip. I hate to see what you think of it when it goes back on
    brend's Avatar
    Oct 2015
    Same where
    Working with these banal chips is easy?
    If you can't handle this simple job then
    there is nothing to advise here!..............
    Throw this idea out of your head and get somewhere to wash dishes.
    There is certainly simple!
    May 2019
    Ok Brend thanks for the help mate you are a real inspiration.
    I can see why in the last 11 years of doing this I didn't bother posting anything. Such a positive crowd.
  11. #11
    May 2019
    On a positive note I managed to finally get a read out of the bloody thing.
    Here is the dump if anyone is still happy to help me for IMMO off.
  12. #12
    May 2017
    here you go.
    magic buttons
  13. The Following User Says Thank You to Lambda1 For This Useful Post:
    Hebbydee (23rd May, 2019)
  14. #13
    May 2019
    Thanks Lambda1 I will download it once I am able.
    Any ideas as to why I keep getting sent to the login page when I go to download your file saying I am not logged in?
    I manage to download any other file in other threads.
  15. #14
    brend's Avatar
    Oct 2015
    Same where
    You instead of hysterics to roll up and arise, it would be better to listen to what experts tell you here.
    And here mostly work with dumps, this means that to communicate you must know how to use the programmer.
    Here nobody will teach you this ,especially with such banality!
    Your whining won't get you anywhere!
  16. #15
    May 2017
    Not enough helpfull posts, not enough recommendations...
    Download here:.xup.in/dl,18697336/beetle_read_fairchild_24C02.bin/
    PW:digitalkaos
  17. The Following User Says Thank You to Lambda1 For This Useful Post:
