Results 1 to 3 of 3
    Croatia
    Default Hyundai Getz 2002 Mechanic Code Lost Both Keys
    I need help getting the four digit mechanic code (T.X.X.X.X) for Miracle A9 key cutting machine so I can program a new key.
    What methods are available for getting the code without any original keys (besides getting the lock out of the car and making the key from the lock itself).
    VIN:KMHBU51HP3U029070
    Dec 2010
    Nottingham
    you could use the lishi HYN11 pick and decoder and pick and decode the lock without removing it , or send the vin to a code broker or some key suppliers and buy the key code which will work as long as the car hasnt had a lock change , the lishi tool will decode the correct key even if it has had the locks changed of course.
    Croatia
    Thank you very much!
