Results 1 to 7 of 7
    Default Bmw E46 EWS need add used key to dump
    Hello, I need to add the following key to dump from Ews3 The car have allready a key , witch is key nr 02 .
    Can someone add the following key to dump . Here is the picture with the key made from zedbull and the dump.
    ews3.rar
    Is this possibile or just blank can be programmed?
    newone's Avatar
    Oct 2016
    just program a blank to an unused position and it will be ok
  4. The Following User Says Thank You to newone For This Useful Post:
    cosminell (22nd May, 2019)
    May 2019
    Quote Originally Posted by cosminell View Post
    You dont have to program anything into EWS on E46 just cut the key turn new key 5 times in ignition to position 2 and back, hold unlock button on remote while pressing 3 times on lock button and key is programmed.
    hope this helps.
    Happy programming
  6. The Following User Says Thank You to One2key For This Useful Post:
    Meat-Head (23rd May, 2019)
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by One2key View Post
    hope this helps.
    Happy programming
    WTF???? Are you serious?
    If yes, you know nothing. So stay away to put bad and wrong comment!!!
  8. #6
    May 2019
    Quote Originally Posted by lion0304 View Post
    sorry i forgot it has rolling code and needs programming this instruction is only for used key that need rematching after battery is dead.
  9. #7
    kiszka's Avatar
    ews3.rar
    this transponder is only suitable for scrap to the smelter
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
