    Croatia
    Default Alfa 156 1.9D 2002 security code extraction
    Need help!
    I had to program the remote for the car in the title. My diagnostic MRPPAD tool didnt extract the right code (64816 the wrong one).
    But it did save the EEPROM file. Is there any way to extract the code from the EEPROM file (file is in the attachments).
    I would really appreciate any help.
    Thank you.
    jodge's Avatar
    Mar 2017
    Did you read the MC68HC05B16?
    Your eeprom is too big for that..it's only storing 256byte
    Croatia
    Hello
    Here is the file from HC05B16.
    Please give me the code.
    Thank you ...
    jodge's Avatar
    Mar 2017
    try this: 42510
  5. The Following User Says Thank You to jodge For This Useful Post:
    Mezz_cro (23rd May, 2019)
    autochei's Avatar
    Mar 2013
    romania
    Dump recognized: OK
    Programmed keys: 0
    PIN: 67114
    Part#: 5 i think it s something strange with ur dump u have 0 key in dump
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by autochei View Post
    Dump recognized: OK
    Programmed keys: 0
    PIN: 67114
    In this car the remote and immo are using two different box and OC two different pins. The immo box could be green label id44 (93c56 256byte) or blue label id46. The remote box contains only one 68HC05B16 MASk: 0D60J
    He needs the remote pin
  8. The Following 2 Users Say Thank You to jodge For This Useful Post:
    autochei (23rd May, 2019), rokibar (23rd May, 2019)
