Results 1 to 7 of 7
    systemlinux's Avatar
    Oct 2018
    CDK
    Default CLEAN EVENT AIRBAG NISSAN ROGUE 2017
    Module AUTOLIV NISSAN ROGUE 2017 98820 5HK0A
    MCU INFINEON XC2336B-40 FLASH 1 64KB
    Attached image of the module
    Ukraine
    This is code flash, must be data flash. Where is the part number?
    Oct 2018
    CDK
    modified publication, are the data now if you excuse
    Ukraine
    You cleared file.
  5. The Following User Says Thank You to Vladimir.zheurov For This Useful Post:
    systemlinux (23rd May, 2019)
    Oct 2018
    CDK
    thanks for the master contribution, but I get an error when I load it in the MCU.
    although I have loaded it with the error, now in the vehicle I figure B1401-00 CONTROL UNIT (UNIT MALFUNC)
    Oct 2018
    CDK
    Thank you very much but now I register a DTC B1401-00 UNIT MALFUNC.
    when I recorded the modified file I got an error in sector 0X000F300
    Ukraine
    Switch on/off the ignition several times and the error should disappear if you have correctly writed the MCU.
  9. The Following 2 Users Say Thank You to Vladimir.zheurov For This Useful Post:
    juozas10 (25th May, 2019), systemlinux (28th May, 2019)
