    Member krug's Avatar
    Jun 2017
    UK
    Default VW jetta 2007 ABS pump problem 01276 fault
    Hi can anyone suggest next step in reparing ABS pump VW jetta 2007, fault code 01276 - abs hydraulic pump (v64) electrical fault in circuit. Checked fuses (ok) , removed pump dissemble powered up motor and it spins, opened module checked positive pin coming on red pin ive marked, blue has to be negative but nothing coming on it. Now im a bit stuck, don't know what to look for.
    Any suggestions welcome.
    Thx
    Jul 2013
    yorkshire
    So you didn,t check wiring. You need to check with load test not just with meter
    Nov 2016
    Chceck wiring and explicitli check the fuse near the battery.
    May 2019
    @Stopro92: that's right.
    Since there are between 5-7 stripe fuses from time to time broken.
    sometimes you do not see that they are broken because they corrode underneath.
    Jun 2017
    UK
    Power coming to ABS plug, that why I opened ABS module to inspect
    Jun 2017
    UK
