Does the security light stop flashing when you remove the security box? And start flashing once you plug it back in? Do you have a way to read the key data and we can add it straight to dump? Also have you checked the dump after trying resync procedure with key to see if it has changed? Once virgin immobox is plugged back in the procedure is as follows:
1.Insert first key to be programmed, light will stay on for a couple of seconds then extinguish. 2. Repeat step for additional keys 3. Press brake pedal 5 times within 15 seconds to exit procedure. Then test, check eeprom data and report.
Did u ever resolve this problem? Currently having the exact problem with a 2001 Rav4
Your immo off file
miloudmess (28th November, 2021)
Anachemare you sure file rav4_Imm_off.rar work
