Results 1 to 15 of 16
    Post ADD KEY peugeot 107
    i have peugeot 107 does not star
    I HAVE DTC:key identification permanent fault
    error communication with immobilizer
    please can you help me?
    Master key should be: B3
    esse's Avatar
    france
    hi,
    check your PM
  3. The Following User Says Thank You to esse For This Useful Post:
    taxi300 (23rd May, 2019)
    Quote Originally Posted by esse View Post
    hi,
    check your PM
    not the same immobox ,mine is 89748-0H010-00
    and dump 24C04 is different
    thakns
    lion0304's Avatar
    Oct 2014
    You read wrong box, this this dump isn't immobox.
  7. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    esse (24th May, 2019), taxi300 (26th May, 2019)
  8. #6
    Quote Originally Posted by lion0304 View Post
    yes is immo box Valeo 89740-0H010-00 with 24C04§§§§§§§§§§§§§§
  9. #7
    esse's Avatar
    france
    hi
    it s not immo box, it s central lock
    ref 89780 0h021 for immo box
    look pdf i send you
    BR
  10. The Following 3 Users Say Thank You to esse For This Useful Post:
    ampibali (12th February, 2021), hsnlpy (10th March, 2020), taxi300 (26th May, 2019)
  11. #8
    HI you're right in the end I find immo box so if the pg1 is 53, write the key in position 2
    if the pg1 is 33, you must write the key in position 1
    but mine the pg1 is B3 so what position do I have to write the key?
  12. #9
    I WROTE TO THE FIRST AND I DID THE SYNCHRO BY THE SHUNT OBD IT DID NOT WORK PLEASE CAN YOU HELP E TO START IT THAKS
  13. #10
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by taxi300 View Post
    Your key already in the dump in position 1.
    Sync pin 4 + 13 OBD with igntion ON for 35mn
  14. The Following User Says Thank You to lion0304 For This Useful Post:
    taxi300 (31st May, 2019)
  15. #11
    what I did but it did not work
    I just bought a 2data key I will test it tomorrow
  16. #12
    hi peugeot 107 has started
    resolved!!!!!!!!!!!
  17. #13
    Jun 2016
    world
    resolved!!!!!!!!!!!
    hi,
    i have the same situation but where can i located immo box?
    thks.
  18. #14
    Dec 2015
    hi
    look pdf i send you
    BR
    Can you send me also pdf about location immo box ? i have problem with car over 10 days.Can't start as well..
  19. #15
    esse's Avatar
    france
    here’s the tutorial but in French
  20. The Following 3 Users Say Thank You to esse For This Useful Post:
    hsnlpy (11th March, 2020), janusz21 (10th March, 2020), Nicolas13007 (10th March, 2020)
