Results 1 to 12 of 12
    Member bupyc's Avatar
    Aug 2018
    Default Audi A4 B6 RB4 speedometer, need help.
    Hi Guys.
    I want to change my friend speedometer, but the new one has more km.
    Can someone make me 0Km? Then I would write new Km with VCDS.
    I've read eeprom.
    Nov 2016
    VCDS will not change the mileage.
    levisdj's Avatar
    Apr 2010
    EcuLand
    what eep inside ? ??
    Aug 2018
    eeprom 24c08
    if it is set to 0km, you can re-tune with VCDS km.
    levisdj's Avatar
    Apr 2010
    EcuLand
    Put donor dash original value here, I can help you with this, but what about immo data ? you will have to adapt dash to vehicle
    Aug 2018
    I have already adjusted the speedometer and the car is running.
    I got login for that.
    Now only has to set Km stand.
    it is a 8E0920900
    brend's Avatar
    Oct 2015
    Same where
    8E0920900L
    NB!!! Don't ask in PM old file password , Im not remember.
    Aug 2018
    yes right "L" at the end 8E0920900L
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Do you still need to edit your file at zero kilometers?
    Aug 2018
    Yes that's right
  11. #11
    Sep 2013
    put original mileage
  12. #12
    Aug 2018
    Hey thanks to everyone who wanted to help !!!
    I did it.
    VAG EEPROM Programmer + KKL cable
    Thanks to all
  13. The Following User Says Thank You to bupyc For This Useful Post:
    sagie (26th May, 2019)
