Results 1 to 10 of 10
    May 2018
    Albania
    Default Audi A6 3.0 v6 tdi 2007 with edc 16cp34 help checksumm error calculate for full bdm
    Got this morning this Audi A6 3.0 v6 tdi 2007 with edc 16cp34, car looks in limp mode but no check engine light only dtc are two inlet manifold runners bank1 and bank2 (normally when these are faulty check engine light stays on but the car runs good) anyway no signs of dpf soot acumulation did all resets with autel on dpf replacment ecu and diff press sensor all reseted still car stays in limp mode. while reading ecu as full bdm when saving file after saved ktag complains about checksumm of full bdm content, read separatelly mpc 564, flash, and eprom 95320 and for none of these files separatelly ktag doesnt complain for checksumm.error, put the flash file on ecm titanium and the file doesnt match with none of the families. is this a case of an previsious tuner messing up with files on ecu? should another original flash file or full bdm cure the problem? Looking for someone who can explain this inconvenient better,
    can someone repair files for me please definatelly is checksumm error
    joker01's Avatar
    Jan 2018
    your file is mod .... it seems to me dpf badly done.
    the dtc table has been reset for this you have limp mode but no dtc spy ... later I see if I have a file ori bdm or I try to reconstruct it.
    upload a file bdm ori and see what mistakes you have .....
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  3. The Following 2 Users Say Thank You to joker01 For This Useful Post:
    bobolin4o (25th May, 2019), oltianmunga (25th May, 2019)
    joker01's Avatar
    Jan 2018
    try this file ori reconstructed
  5. The Following 2 Users Say Thank You to joker01 For This Useful Post:
  6. #4
    May 2018
    Albania
    thanks bro ill try and report
    May 2018
    Albania
    this is only flash right?
  8. #6
    joker01's Avatar
    Jan 2018
    yes only flash
  9. #7
    May 2018
    Albania
    your file wont go in it says checksumm error
  10. #8
    joker01's Avatar
    Jan 2018
    ktag is ori or clone???
    have another tool for try????
  11. #9
    May 2018
    Albania
    ok ill try that, someone else corrected flash checksum and it accepted no important dtc on diagnose but car wont start
  12. #10
    joker01's Avatar
    Jan 2018
    I think it's not a file problem ....... on the file I made winols finds correct cks and ecm recognizes the driver .......
    try reinstalling ksuite or using another version .....
