Results 1 to 5 of 5
    Nov 2018
    Default Different ECU SW Versions
    Hi guys
    Is it possible to do the following:
    I have a 2 cars. Both are VAG 1.9TDI with Bosch EDC15 ECU. But HW and SW versions are different. Can I just use the same WinOLS script for example: DPF off / hardcut limiter or any other thing on both maps? Or do I have to create new WinOLS scripts for every HW and SW version although they are basically the same ECU (1.9TDI EDC15)?
    dominik.m's Avatar
    Jun 2009
    POLAND
    EDC15 VAG does not have DPF!
    Nov 2018
    it's just an example... just a general question about maps in same ECUS but different SW versions... stage1 skript w/e . Can I just use the same WinOLS script for on both maps? Can I just apply the exact same maps on both altough they have different SW versions? or do I have to tune them individually?
    Jun 2013
    EU
    The script itself will tell you if you are allowed to run it over a certain ecu dump.
  5. The Following User Says Thank You to morgano For This Useful Post:
    101newbie (30th May, 2019)
    Nov 2018
    thanks mate yeah just saw that in WinOLS
