Results 1 to 2 of 2
    Feb 2016
    UE
    Default sid206 -Ford Kuga 2.0 TDCI - pinout
    Hello, maybe someone has a complete ECU sid206 pins - Ford Kuga 2.0 TDCI? I need to locate the pins from the fuel temperature sensor and the crankshaft position sensor. The installation was repaired after the accident, it is possible that the cables are being stoned. I am grateful for any help.
    Feb 2016
    UE
    The diagram of ECU outputs is still needed! The car already starts but generates errors related to the gas pedal. All three plugs have been cut off at the accident. The cables are soldered in accordance with the colors but can be stained. The schematic will make the task easier.
