    al70's Avatar
    Nov 2017
    Éire
    Default carprog security access error
    hi guys, im trying to correct odometer of 2009 audi A3 8P 2.0 tdi with carprog online, i keep getting this error, there is one lost key with this car, would this be the problem ? or would there be something wrong with the lib file, i'm lost, any help will be appreciated, i've enclosed some pics of the error, notice that the software changes to ff.ff at the top of the screen, cheers and goodluck.
    mastaflex's Avatar
    Jan 2009
    FR47310
    maybe you are trying wrong version in menu , the lost key is not problem as you are actually using a valid key to put ignition
    al70's Avatar
    Nov 2017
    Éire
    hi, thanks for the reply, i've tried two options with no luck
    Aug 2019
    Did you end up fixing issue.i have same problem
    Oct 2017
    Quote Originally Posted by Dodo123 View Post
    My suggestion: it doesn't work with clone Carprog 8.21
    I checked with Passat b6, it only reads: Part Number etc.
    Touran, too.
    Jun 2020
    Was anyone able to find a solution?
    I get the same error, while trying to adapt an 8P white cluster.
