Do CS with mpps.
Don't forget Thank button
Do CS with mpps.
crixtian (28th May, 2019)
your file...........
fix you cks
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
How have you solved the hot start? I do not see any change compared to the original?
https://i.imgur.com/mNj36cb.png
Thanks!
Oh sorry, hot start here is in two places 192840 and 1E7B74 as Egr, night work
Is it necessary to modify it in the two blocks?
And if your answer is yes, can you rectify it, please?
Is it normal to record these values when the EGR is deleted by software?
https://i.imgur.com/TszjGLi.png
Thanks!
Yes, egr valve shut off
All right, thanks again!
@mysterious, I made about 100 km after the flashing and everything is fine so far, thank you!
I forgot to ask if the error ''Emissions Garage'' would appear again after a few km (I ask because I see that many users also request DTC OFF too)?
Egr valve's DTC also are off
crixtian (31st May, 2019)
