Results 1 to 13 of 13
    May 2016
    Post For audi experts a very special misfire problem
    Hello
    Im an audi master technician and im stuck with a misfire problem. Its an audi q5 2.0 tfsi 2010 , it has misfire in cylindre 1 at idle and when accelerating everything goes fine . I replaced spark plugs and cylinder 1 injector , coil ,
    2 valve lift actuators for cylinder 1 , copression test gives 12 bars and thats ok , ecu replaced , wiring for coils and injectors testes and everything is in order , no shorcuts no resistance problems. I even took out the cylinder head for visual inspection and nothing wrong with it . Valves and camshaft are ok . I think i checked everything possible with misfire causes and nothing appers yet. I will appreciate your help so much . Ps : misfire is always and only in cylinder 1
    Jan 2019
    I am not an AUDI expert, i just read your post and thought to try to help you if i can
    Is it a costant misfire at cyl 1 at idle ??
    Did you done a cylinder drop test ??
    Do you use scope ?? if so do a relative compression test to get direction for your engine health
    Also scope your cam and crank sensor to be 100% that your signal is good, your flywheel clean, and the marks are spot on
  3. The Following User Says Thank You to Andreastech81 For This Useful Post:
    leverage454 (30th May, 2019)
    May 2016
    Hello yes its a constant misfire at cyl 1 at idle i did a cylinder drop test and that was ok . I didnt use scope yet , when engine is at idle i can hear a noise from flywheel but i thought even if flywheel is faulty it cant affect cyl 1 only. I guess i will re-assemble the engine and i will check signals from camshaft and cranckshaft.
    mastaflex's Avatar
    Jan 2009
    FR47310
    does it make it only when warm or in all cases ?
  6. The Following User Says Thank You to mastaflex For This Useful Post:
    leverage454 (31st May, 2019)
    Jul 2013
    yorkshire
    Looks like a new dmf needed. If flywheel is wobbling sensor cannot read correctly, Autoden "not a master tech"
  8. The Following User Says Thank You to autoden For This Useful Post:
  9. #6
    racin-snake's Avatar
    Jun 2009
    RE CHECK THE VALVE SPRINGS . common fault on FSI TFSI UNITS ..... as is inlet manifold gasket seals and cracks in manifold ( plastic manifolds )
    Do you not have access to TECHNICAL SERVICE BULLETINS or guided test plans as a MASTER TECH ?
    R.S also not a VAG mastertech
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  10. The Following User Says Thank You to racin-snake For This Useful Post:
  11. #7
    May 2016
    Autoden ,im not sure if you know enought that kind of engines, so if so, if i unscrew the 3 three bolts that links the flywheel to the engine without taking the gearbox out the engine should runs ok ?
  12. #8
    May 2016
    Mastaflex,
    Always warm and cold
  13. #9
    May 2016
    Quote Originally Posted by racin-snake View Post
    Yes i have full acces , but for valve springs i checked them and inlet manifold too . Both are ok
  14. #10
    Jun 2009
    Post the vehicles engine code and fault codes present . we need to see what you see to help you .
    Meanwhile swap no 1 injector to another cylinder see if fault follows .
  15. #11
    May 2016
    Engine code is CDNC 2.0 tfsi
    Fault code p0301 and nothing else
    I replaced injector 1 and then i still have doubt on it and i swaped it with another injector and still same thing , and all injector seals are replaced
  16. #12
    Jun 2009
    Have you tested for injector pulse and misfire counter ?
  17. #13
    Have you done smoke test to check for vacuum leaks around cylinder 1 ?
