Thread: Checksum reques
    Member KNSelectronica's Avatar
    Jan 2019
    Spain
    Default Checksum reques 0281010492 - 29f400
    Audi A4 2,5 tdi 0281010492
    edc15vm+
    am29f400 correction doned for immo off solution
    can somebody check and correct the checksum for me.
    will provide the orig file as well.
    thanks in advanced
    May 2017
    here you go.
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    KNSelectronica (12th June, 2019)
    Jun 2017
    Quote Originally Posted by Lambda1 View Post
    here you go.
    What tool did you use to flash?
  5. The Following User Says Thank You to kostask For This Useful Post:
  6. #4
    May 2017
    for flashing can be use any common flasher tool.
  7. The Following User Says Thank You to Lambda1 For This Useful Post:
  8. #5
    TuningInside83's Avatar
    Dec 2016
    Italy
    Il tuo file con CKS ok
  9. The Following User Says Thank You to TuningInside83 For This Useful Post:
  10. #6
    Jan 2019
    Spain
    Was using simple programmer to do immo off on that car, not bench reading and remap. Thank everybody.
