Results 1 to 10 of 10
Hybrid View
    Jun 2013
    EU
    Default Sprinter 519, need help dtc off and associated limp mode off too.
    Hi.
    Need help with this beast, van was in various workshop many times, even dealer.
    They changed lots of parts, ecu not replaced.
    The problem is P0172 00 rich mix on bank 1
    Van lights MIL and enter limp mode. Replaced lambda, turbo, checked leaks,... etc
    Want to try deleting the Pcode and the associated limp mode if possible. Only deleting Pcode not works, i tried, enter MIL and limp with no DTC on diagnostics.
    Here original, thanks in advance.
    Jun 2013
    EU
    Hi.
    Can anyone give a hand here please?
    All mechanical has been reviewed, just need test this on ecu as all live values seem within range and we don‘t know what is producing that p0172 code.
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Do you have xentry? What year and engine is?
    Here to HELP!
    immokill's Avatar
    Jun 2009
    UNIVERSE
    This is vacum problem some leak for sure . I think that no software can be solution .
    Here to HELP!
  5. The Following User Says Thank You to immokill For This Useful Post:
    morgano (2nd June, 2019)
  6. #5
    Jun 2013
    EU
    I think we can have access to an original merc diag equipment if completely neccesary.
    The van is 2015, and was problematic since day one. Already blown 2 or 3 turbos. On another workshop engine was opened and refit, changed all sensors,... thousand euros in invoices and still not solved the issues.
    Where do you suspect the vacuum leak is? My pal checked all hoses and pipes and seen no damage.
    He told me vaccuum is inly used to manage the bypass of the egr cooler. All other actuators are electrical.
  7. #6
    stanislav georgiev's Avatar
    Oct 2014
    България
    Possible Causes. Rich mixture . Inspect the injectors, turbine pressure, and also block the catalyst
  8. The Following User Says Thank You to stanislav georgiev For This Useful Post:
  9. #7
    Jun 2013
    EU
    Quote Originally Posted by stanislav georgiev View Post
    Brother all parameters in live data diagnose session are ok. Van is now mechanically like new, fap adblue egr all is fit in the van and working properly according live data.
    Just need the limp mode and dtc removed for that p0172 error to discard ecu has other errors and p0172 pops up first and not show other errors.
  10. #8
    Jun 2013
    EU
    Any trick what to look for in damos, in order to disable the limp mode?
  11. #9
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default mb
    Here , nodtc no limp mod
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  12. The Following 3 Users Say Thank You to Ignasvw For This Useful Post:
    levisdj (3rd June, 2019), morgano (3rd June, 2019), stanislav georgiev (3rd June, 2019)
  13. #10
    Jun 2013
    EU
    Quote Originally Posted by Ignasvw View Post
    Two days have passed since the file was burnt on the ecu. The van is working fine as of now. No more limp nor dtc, no lack of power,... also no other dtcs that could be waiting behind the p0172
    Don’t know what to think now, faulty ecu or some ghost problem we cannot find that makes ecu think mixture is too rich.
    Thanks ignasvw, you are top
