    Oct 2016
    Default Launch Control Fiat 1.9 EDC16
    Can someone help me set up the Launch Control ?
    Aug 2015
    Launch control 3000RPM,test and report. Pass PM
  3. The Following User Says Thank You to Zalejak For This Useful Post:
    Hamai (1st June, 2019)
    Oct 2016
    [COLOR=rgba(0, 0, 0, 0.87)]it doesn't work [/COLOR]
    Oct 2016
    These are the hysteresis of torque limiting in limp/error mode
    joker01's Avatar
    Jan 2018
    try this...........
    fix you cks....
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  7. The Following User Says Thank You to joker01 For This Useful Post:
    Hamai (5th June, 2019)
  8. #6
    Oct 2016
    Thanks. I changed Gearbx_trqDriveOffF_CUR. It working correctly.
  9. The Following User Says Thank You to Hamai For This Useful Post:
    mancioks (6th June, 2019)
