Results 1 to 9 of 9
Thread: cant scan
    Mar 2008
    Default cant scan
    hi
    installed pli-jade on 600c-pvr via wed interface copied over camd and keys and cable.xml all channels working fine, problem i have is i cant scan, when i try it say's (fatal error, loading networks failed) and i have to press green button and restarts enigma any ideas where i went wrong.
    cheers
    napster
    cheers
    napster
    Sep 2008
    Quote Originally Posted by napster View Post
    hi
    installed pli jade on 600pvr via wed interface copied over camd and keys and cable.xml all channels working fine, problem i have is i cant scan, when i try it say fatal error, loading networks failed and i have to press green button and restarts enigma any ideas where i went wrong.
    cheers
    napster
    I think you have to choose the type of scan.
    Instead of doing a frequency or step scan you need to set it to provider.
    You can then choose bruteforce to do a complete uk cable scan.
    This is what the cable.xml file is for.
    DK Veteran alliv's Avatar
    Jun 2008
    hi
    cheers
    napster
    napster any chance of a link to download this image? i,ve been looking but only seen the 500 version. thanks m8.
    is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
    Mar 2008
    cheers
    napster
    Jun 2008
    thanks napster m8.
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Have you tried reflashing the image in case you suddenly got some sort of corruption?
    Mar 2008
    Quote Originally Posted by Curious123 View Post
    going to give it an other try tomorrow,put backup on for now
    cheers
    napster
    Mar 2008
    all sorted thanks cable.xml file i used was to blame
    cheers
    napster
    Administrator
    Devilfish's Avatar
    Feb 2008
    Glad you're sorted m8.
