Results 1 to 3 of 3
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default MAN tgl 12-240 error EDC 3779-01
    Hi guys..
    I have a question for a MAN tgl 12-240...
    I have EDC 3779, truck goes to safe mode, if I switch off and back on the engine the fault have gone....
    What causes that? Any pressure valve? What is the most recent fault in that common rail?
    Jul 2019
    hi, that is a low fuel pressure fault, obviously i cannot diagnose it from the other side of the internet but i can give you some guidens . firstly you should do a leak off test on the injectors they are know to leak back giving lower fuel pressure, check Mprop valve, all 3 fuel filters, and fuel pressure valve . if you have access to a diag machine that can read live data then let me know and i can help more
    Oct 2020
    hi i have a man cats II diagnostic tool i need help with can you please assit
