Results 1 to 3 of 3
    DK Veteran chipcar cordoba's Avatar
    España
    Default HELP BSI 307 DIGIPROG 3
    Hi i need help , to read bsi 307 95160 in the manual does not look good as you have to do it because the wires do not match the colors with the manual
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. You have to cut line that goes to pin 7,8. This is power to ic, but if ic is on board then you give power to all board, and if your programmer is limitet to 50mA output then you dont have power to ic.
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. This is from NYYO4 cut track in red marker.
