Results 1 to 5 of 5
    alclot's Avatar
    Sep 2009
    Melee Island
    Default Opel year 2001 display doesnt work
    Hi mates,
    The display doesnt work well. Can anyone help me with any tip to fix it and power up pleasE?
    Thanks a lot
    bank's Avatar
    Feb 2017
    Ukraine
    Just change it to another one and swap eeprom 93cXX
  3. The Following 2 Users Say Thank You to bank For This Useful Post:
    alclot (5th June, 2019), Meat-Head (5th June, 2019)
    dominik.m's Avatar
    Jun 2009
    POLAND
    Pin 8 - GND
    Pin 6, 20 - 12V
  5. The Following User Says Thank You to dominik.m For This Useful Post:
  6. #4
    VeryFastSnail's Avatar
    Jan 2019
    First of all you have to make sure that display is not displaying, check it with bright light, you can see if it displays and there are no back light, or display is f**ked...
    Another time you have to provide more information about this cluster, what display does, is there backlight, power on photo and so on, remember, more info you provide, faster response and help.
    If I helped you, feel free to drop me that sweet sweet +1 thank you.
  7. The Following 2 Users Say Thank You to VeryFastSnail For This Useful Post:
  8. #5
    Jan 2019
    these are the steps to diagnose:
    1. Check backlight (do it show text but no color display)
    2. Check LED driver VCC pin. (is it getting power? i.e 5v-12v)
    3. Check if IC is fu**ed, by checking continuity between vcc and GND pins
    4. Check capacitors around IC are they shorted? if so, inject 1v into capacitor and find what gets hot
    5. If LCD driver is good, but there are no backlight, check bulbs/leds. and if those are good, check power mosfets. (often if those are bad, they will get really hot)
    More advanced: use osciloscope and see data lines patterns, are there some movement? any PWM signals or just steady 12v/5v/GND?
  9. The Following User Says Thank You to VeryFastSnail For This Useful Post:
