ECU help MED9.1 issues wake issue
Results 1 to 3 of 3
Hybrid View
    Apr 2019
    London, UK
    21
    Downloads
    Uploads
    Default ECU help MED9.1 issues wake issue
    Audi A3 2.0TFSI AXX 2006
    I did a ID and remapped the ECU stage 1. It was all ok and fine. It remapped ok. The car drives normally
    The issue is i can no longer ID, READ, WRITE or use recovery. I keep getting ERROR WAKING ECU
    The car drives and starts fine still.
    Also when i plug in vcds diagnostics it wont communicate with the engine module to read fault codes
    Any advice is appreciated
    Jun 2013
    EU
    962
    Downloads
    11
    Uploads
    The “tune” you uploaded to ecu blocked obd access.
    That things happen when you flash to ecu files that are “from not known and trustworthy father”.
    Next thing to try to gain access again is dismantle ecu and do BDM.
    But following your career with this car in forum i encourage you to stop playing with it yourself and go to a local experienced tuner, pay for a good work and be happy enjoying your well remapped car. Otherwise i will see you in forum in next days complaining about a good car converted by yourself games in a non starter. Just a friendly advice.
  3. The Following User Says Thank You to morgano For This Useful Post:
    robinbga (6th June, 2019)
    Apr 2019
    London, UK
    21
    Downloads
    Uploads
    Quote Originally Posted by morgano View Post
    I had a map pack I purchased but before I did the flash I asked someone that does my files and they said it's a good file so I flashed it. But you are right I should just go to someone properly where I am.
    It's very weird I can still use obd but only engine won't scan everything else is ok
