Buy less than 30$ the AK90, it's the best tool for EWS.
Hello, i want to program key for a BMW e46. I used my CGPro 9S12 for reading chip 0D46J on EWS3. Because there is not a arrow on my adaptor, so i identified arrow as the photo. My procedure as following:
Align pit on chip with a arrow on adapter ( arrow as photo)
Choose immobilizer/BMW/ EWS3 0D46J
Click "Read" button
But it uassually show message "Power on operation failed" as photo or show all "0" or all "F".
Can anybody tell me why i can not read this chip, what did i do not correctly when read the chip?
I can not find any guide read this chip with my CGPro 9S12 on internet. Thanks
trunggt2007 (6th June, 2019)
pins need very very good cleaning with sharp tool
then need very hard pressure over the socket
With adapter, usual you cannot put the wrong way. One corner is diffrent than others.
Use thin sand paper and clean the pins. After clean again with acetone.
Thank you much. i do not have real EWS3 here for taking photo, but i aligned dot on chip and arrow on adaptor as these photos. i have red cas2 and cas3 already by my CGpro 9S12. But it is the first time i use adaptor for reading chip 0D46J on EWS3. i pressed adaptor on chip but i see it seem loose.WhatsApp Image 2019-05-24 at 21.17.40.jpgUntitled.jpgUntitled-2.jpg
EWS editor 3.2.0, it's the best tool for EWS 3 ,0D46J .
trunggt2007 (7th June, 2019)
Aligen is OK
If you still cant read - change the tool
I've never successfully read EWS with cgpro - I gave up trying. Buy AK90.
hi, i am reading with vvdi prog adapter without any cleaning sandpaper needed. safe and trouble-free.
