    Jun 2019
    Default Opel Vivaro EDC16C36 P0089
    Hi, New to this forum. So Hi to evryone
    I'm currently working on a opel vivaro 2.5 With an edc16C36 which was chiptuned the wrong way . so it lost injector coding
    Now i have coded the injectors with Delphi , acording to the numbers that are shown on the injectors in the engine bay. now that works fine, the ecu stores the injector codes But still it will only crank and not start. it starts for a few secs and than dies off again , and with that the code P0089 is stored. So the fuel pressure is to high,
    Do i need to recode the fuel pressure sensor also ? I have read about this, but i don't have Renault Can Clip.
    original file is attached
    Hope someone can help
    gr richard
    Jun 2013
    EU
    For p0089 i would start by replacing fuel filter.
  3. The Following User Says Thank You to morgano For This Useful Post:
    stanislav georgiev (6th June, 2019)
    Jun 2019
    The fuel filter on the car is new, and before any OBD actions the car ran fine.. so that's not likely to be the problem
    Jun 2013
    EU
    Upload original file to ecu and see if problem persist.
    Jun 2019
    Allready tried that, Same problem.
    Senior Member Novik_UA's Avatar
    With Can Clip in repair menu choose right high pressure pomp type, for sure if injectors codes lost, it lost too.
  8. The Following User Says Thank You to Novik_UA For This Useful Post:
    morgano (6th June, 2019)
