Results 1 to 15 of 23
Thread: VW Passat ELV
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Default VW Passat ELV
    Hi...
    we have here a VW Passat B6 2006...
    damaged ELV...
    we will get brand new from VW today...
    someone know procedure to adapt...?
    only odis ONLINE...?
    on old ELV there is no MCU/Eeprom...
    Oct 2014
    Netherlands
    You can easily adapt virgin ELV using VCDS adaptation channels if you have PIN from CCM (google for procedure).
    But you need to unlock the CCM first using the old ELV so it must still be working!
    If it isn't working anymore then it is hard to fix ...
  3. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    Faraday (15th June, 2019), figani (6th June, 2019)
    figani's Avatar
    Feb 2018
    Not good, old is totally dead...
    No communication possible...
    When old is complete dead, like in my case...
    Is it possible with new ELV and Odis online...?
    Oct 2014
    Netherlands
    I don't know what the normal solution for this situation would be, so I am curious to find out.
    dimon9555's Avatar
    Oct 2012
    Belarus
    Can be done: VCDS + dump + $
  7. The Following User Says Thank You to dimon9555 For This Useful Post:
    H2Deetoo (6th June, 2019)
  8. #6
    brend's Avatar
    Oct 2015
    Same where
    VCDS?How?
    If old totaly dead!
    And what you mean dump and $ ?
    Quote Originally Posted by dimon9555 View Post
  9. #7
    figani's Avatar
    Feb 2018
    With dump you mean, from ccm...?
    and what you are meaning with $...?
  10. #8
    brend's Avatar
    Oct 2015
    Same where
    If ori totaly dead only odis online help you!
    Without old ori elv with vcds impossible set security because ccm is locked.Only odis online can open this online away for programming new elv.
    Correct me if I'm wrong!
  11. The Following User Says Thank You to brend For This Useful Post:
  12. #9
    dimon9555's Avatar
    Oct 2012
    Belarus
    you are wrong
  13. #10
    figani's Avatar
    Feb 2018
    you are wrong
    very helpful...
    I found a link under ross tech forum....
    they explain it, with a new ELV how to adapt...
  14. #11
    Oct 2014
    Netherlands
    Yes that's the procedure, but it will only work once the CCM has been unlocked using orig ELV.
    If orig ELV is dead as you say you need another approach.
  15. The Following User Says Thank You to H2Deetoo For This Useful Post:
  16. #12
    Oct 2014
    Netherlands
    dimon955 is right, there are other more private solutions ;-)
  17. #13
    figani's Avatar
    Feb 2018
    will try it with odis online later and give feedback...
  18. #14
    brend's Avatar
    Oct 2015
    Same where
    Only odis help you!!!
    Prove me wrong!!!
    you are wrong
    dimon955 nathing explane no information from him!
    Just totaly nothing and he is right!?
    Grate.............
    Good luck with nothing!
    Quote Originally Posted by H2Deetoo View Post
    And what's it?
    It's not for this what you try talk!!!
    Quote Originally Posted by figani View Post
    very helpful...
    For this problem like in here can solved only odis!!!
  19. #15
    Oct 2014
    Netherlands
    @brend don't shout so much because you don't understand!
    Like I said there are more private solutions, I have one and it seems dimon955 also.
