2014 Toyota Prius Japan, need help with EEPROM for FOG light tell on console to work
Results 1 to 15 of 15
    Mar 2019
    11
    Downloads
    Uploads
    Default 2014 Toyota Prius Japan, need help with EEPROM for FOG light tell on console to work
    Hi Guys
    Got a bit of problem, I've got the file (attached), that works fine on the car, the only thing is that the front Fog light tell on the dash does not come on when the fog is on, -i suspect that the vehicle this dump came of doesn't have any front fog... it works with the original jap file (also attached) but not the one i use to convert it to English and miles.
    Any help would be much appreciated.
    Mar 2019
    11
    Downloads
    Uploads
    I've tried Techstream and there does't seem to be any selection for front fog.
    Mar 2019
    11
    Downloads
    Uploads
    I've tried each of these bytes swapped over, no luck tho.....
    Meat-Head's Avatar
    7,859
    Downloads
    Uploads
    Can you cut and paste the two files in half, see which half it is in
    and/or is there anything on here you can leech, incorrect.
    if you remove eeprom does said light work
    is there any used clusters on eBay
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
    fahadv (10th June, 2019)
    Mar 2019
    11
    Downloads
    Uploads
    see attachment...
    Meat-Head's Avatar
    7,859
    Downloads
    Uploads
    Too small to read what is said. If it’s just front fog take it not an option putting separate led in?
    unless something daft like miles and fog km no fog
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
  9. #7
    Mar 2019
    11
    Downloads
    Uploads
    Third time lucky...
  10. #8
    Meat-Head's Avatar
    7,859
    Downloads
    Uploads
    Ok, Iím currently in the bath, not got a computer to hand, as put it away to decorate
    you sometimes find a dump is repeated, so if you open one of the hex files, is there repeatedly
    and/or can you not concentrate on change jap from ok to miles, then correct km
  11. The Following User Says Thank You to Meat-Head For This Useful Post:
  12. #9
    Mar 2019
    11
    Downloads
    Uploads
    When i got the car originally, it was in Japanese and KM, the dump on the left converted it to English and Miles. The only thing wrong is the Front Fog Light tell on the console.
    maybe someone has another dump i could try?
  13. #10
    Mar 2019
    11
    Downloads
    Uploads
    Dam... not having any luck at all
  14. #11
    Meat-Head's Avatar
    7,859
    Downloads
    Uploads
    Ok, the brand of it, do a search for it, see if you can leech any and compare.
    Sometimes stuff can be swapped sometimes not
    try in google (change brand to correct one)
    C86 dense site:digital-Kaos.co.uk
    Can you get set from junk yard
  15. #12
    Meat-Head's Avatar
    7,859
    Downloads
    Uploads
    Does this help? Reading first post holding trip to convert km to miles (not work)
    https://www.digital-kaos.co.uk/forum...eedo-km-to-mph
  16. #13
    Mar 2019
    11
    Downloads
    Uploads
    Junk yards only have UK spec consoles, which dumps dont work from, i need to convert the Jap ones i have to English and Miles.
    the KM to miles button only work on USA and Canada as far as im aware, hence the reason for the dump i uploaded.
  17. #14
    Mar 2019
    11
    Downloads
    Uploads
    BUMP.........
  18. #15
    Feb 2009
    10
    Downloads
    23
    Uploads
    Quote Originally Posted by fahadv View Post
    Hi Guys
    just use dump form uk cluster works fine do them all the time no problems
